Tenda MW6 Mesh Wi-Fi?
15 Nov 2020
West Sussex
I have connected the primary node to my router (via an ethernet cable) in my study.
However, I still have a weak Wi-Fi signal down the end of my house (i.e. from the mesh WiFi connected MW6 secondary node)?
Question: – could I (hard wire) connect a switch to the port on the primary MW6 node and then connect the secondary MW6 node back to the same switch via an existing ethernet cable?
For the Record; the third node in the lounge is fine - its just the one at the end of the house I think would benefit from hard wiring (if its hopefully going to be possible)?
Thank you Tally - excellent! I will go ahead an purchase a compact 5 port switch and give it a go...
Much appreciated, Nick
