- Joined
- 4 Mar 2025
- Messages
- 4
- Reaction score
- 0
- Country
Hello,
This is my first post here, and I would really appreciate some advice.
I currently have a consumer unit located high up in a hallway. The main supply now needs to be brought in from a meter that has been relocated more than 3 metres away.
My proposed solution is to run a 16mm² SWA cable into a metal adaptable box, with cable entry at the bottom left-hand side of the consumer unit, and then terminate it into the isolator. I would also relocate the doorbell transformer.
Would this be considered a suitable approach, or are there better alternatives I should consider? Also what is the best way to seal the cable entry from external to the inside.
Thank you
Thank you
