can I test a capacitor ;
300 MFD
125 VAC
with a multi metre?
Cheers Ian
300 MFD
125 VAC
with a multi metre?
Cheers Ian
It is, if the OP is interested in measuring its capacitance. He could start by using the resistance range of his meter. It will initially indicate very low resistance, as the cap charges up, but should then gradually rise. If it remains low for a long time, even with the low voltage a multimeter, then he's very probably got a dead capacitor.So 20 is too low
Indeed - that could well be why the OP is checking the capacitorIf it is refusing to start, even though there is an electrical supply to it, the capacitor is one of the first things to check.
Hi Dave hows it going?
motor spec;240 V
current 5 A
H P 1
RPM 4500
The motor is quite big 6 1/4" Dia
The main RCCB in the workshop trips,
80 AMP
Tripping current 30mA
The main breaker further back down the line also trips;
RCCB 100 A 300 mA
18R 100/300/4
Cheers Ian
uf is mfd
micro farad
( think its lower case)
uf is mfd
micro farad
No it is not uF, it is µF. (Greek letter µ).
my multi metre has 20 uF position
