1Kw single phase motor should be easy to start. 300microfard for that size of motor seems a bit odd (large) but so does using a 125VAC capacitor on a 240 volt system - even if it's in series with a winding.
To check out your problem of intermittent tripping (as against a constant fault) requires some real test equipment. As had been said earlier a megger is essential to check for earth leakage.
Do you have a circuit of the planer wiring.
Can you supply a photograph of the actual capacitor (with writing)
Is the planer motor an induction motor or a universal one (has brushes)
JW2 I'd inadvertently used 330 in my calculation rather than 300, hence 9.6 vs the correct 10.6
