Texecom Excel
5 Aug 2018
Hello
Have installed a new Texecom Excel (pcb has no fuses on it) with new PIR x 5 used existing wiring with continuity check done on setting up the PIRs are open on checking there is 12 volts on the board but lower than 1v on the aux terminals PIRs not working?
Well, at least tell us what was wrong, then we can all learn something.
Found wrong connectors had been used on zones one and two they where being feed back to panel two 6 core each to one eight core cable bad connections (was getting continuity with everything dissconnected) probably explains the old one playing up (was installed by previous owner) but put some chocolate blocks on to separate circuits all working fine just shows sometimes need to do bit deeper investigation when using old cable runs.
