I am trying to set my Texecom Premiere Elite so that i can use the tag to set the alarm but the alarm can only be unset by entering a valid user code (not via a tag).
I have a key box nearby the alarm panel where everyones keys are stored, each persons keys has their own tab for the alarm. There will be instances whereby one or more tag will be left in the box with evetyone out and the alarm set. I dont want someone to be able to break in and find a tag and unset the alarm.
Therefore i thought of two ways:
1. use the tag and the code to unset
2. Use a code only to unset, with the tag being used to set (or code if desired) - this is my preferred option
The manual hints at this but i cant work it out. I have disabled the "Cst O/P 2.B-CODE" option in Wintex so that the user can unset using the code, but it still allows the tag.
I tried enabling the "Cst O/P 2.A-TAG" option in Wintex but this seems to have no effect and can still use either the code or tag.
I guess the way to do it is by setting the correct option in the Custom Outputs, but i cant make head to tail of what i need to change.
Can anyone help?
Can anyone help?
