Does anyone know if the Texecom premier elite 24 kit 0011 metal kit is a wired system I’ve tried looking for a manual but some are abit confusing just needed to check b4 I buy thanks
Ok so I’ve ended up with a telecom 48 metal with a prox keypad ,well it’s on its way .
So reading through online instruction I’ve to wire it all up then power up with battery then hold button on inside panel , then mains power
Then program is this correct or can I program on kitchen table then install thanks
