Texecom Premier Elite which firmware version?
5 Feb 2013
Worcestershire
I have a Premier Elite 48W Panel which seems now to be discontinued. I would like to install Texecom Connect Smartcom to upgrade my ComIP.
Do I instal the v4.0 firmware PremierEliteFlasher_1_8_4_3_Setup.exe or the latest 4.02 PremierEliteFlasher_1_8_6_0_Setup.exe given my panel is now discontinued?
Am I likely to have any problems with the Premier Elite 48W and Texecom Connect?
24 May 2016
Kent
The elite platform is not discontinued just that particular variant of panel all W panels have been replaced with the 64-W.
SmartCom requires V4 upwards, so either would be fine but 4.02 would be preferable. You won’t have any problems but may have to relearn all your wireless devices. Remember to save your profile on wintex prior to flashing the panel.
5 Feb 2013
Worcestershire
I've just got around to this, it could be a dumb question but I've just loaded the flasher software and I have a choice of a number of .mot files. I can't find any reference to the naming convention. I have a Premier elite 48W. The most obvious is p48_V4_00_ but then I have options of 24_LS1, 24_LS2... 24_LS6,
5 Feb 2013
Worcestershire
Thanks guys, I received a very quick response from Texecom, LS1 is the English language pack which I would have probably found out after a couple of attempts but I don't want to brick it...
5 Feb 2013
Worcestershire
Mission success, relatively painless, even managed not having to relearn everything. The basics on the App work really well, there seems to be some instability in the more advanced functionality which causes it to shutdown if the wrong inputs are provided.
17 Feb 2008
Berkshire
@mattice I am looking at this, with the app can you actually arm or dis arm the system remotely and what did you use to flash the firmware? (Flash Interface PCB?)
