Texecom Riccochet Sounder won't re-connect after battery replacement
5 Jun 2026
I have a Texecom GEW-0001 64-W Wireless control panel, with a Premier Elite Odyssey 3-W GBR-0001 Wireless Bellbox. The sounder was complaining of a low battery, so I replaced them with the Energiser Lithium batteries reccommended. I have 14v on the terminals. The sounder would not re-connect to the Riccochet network. In debugging it, I accidentally deleted all the devices. I have since added them all back, but the sounder still won't re-connect. Even after unmounting it, and performing the re-connect from next to the alarm box, I just get the fast flashing left light.
I followed the documented procedure, by moving the jumper to off for a period, and back to on, both just before, and just after telling the alarm to listen for new connections. All other devices re-connected fine, why is my sounder not? What else can I do to debug it?
Did you add the sounder ?
Just your saying it wouldn’t reconnect but you deleted all the devices off and then relearned back on.
So are you saying you relearned the devices back on and they all work but tge sounder won’t trigger and is in hold off mode?
