Texecom Veritas 8 set up help
18 Aug 2007
Cheshire
I replaced my old alarm panel with a Texecom veritas 8 over the weekend and have been trying to set it up tonight. The wiring is all correct and I was working throiugh the various settings from the manual. I changed the 4 digit code to the one that I would be using. I know it accepted this as I could use it to enter programming mode.
I went to try it on full set for the first time. Entering the code plus FULL caused it to flash the unset LED a couple of time but it wouldn't set the alarm.
Eventually I got it to count down the exit timer, I think by pressing FULL on its own. I let it go into alarm, but then it wouldn't stop and reset when I entered my code.
Panic stricken I whipped the front off and disconnected the battery and pulled the fuse.
My brain is now frazzled and my tinnitus through the roof and I'm leaving it off overnight. Anyone familiar with this product shed any light, anything to check, anything I'm missing with the parameters?
TIA.
The user code is not the engineer code ….so you have changed the engineer code …not the user code which should still be 4321
I think you are on the right lines. I'll be trying again later, but looking at the manual, it says Option Code 60 is under the title Program your own code PIN. I think that was the one I changed from the factory setting of 1234.
Just to get the terminology right, the user code is the one I'll be using to set and unset the alarm. Is there anything else I use this number for.
What exactly do I use 4321 for?
Eng code alters the alarm configuration it won’t set or unset the alarm ..
User code sets alarm …you can’t alter the configuration ….
