I'm using a Serial TTL to Ethernet adapter (not the official COM IP) and for some reason when I punch the code in the Wintex digital Keypad and hit yes to fully arm, it only goes to Part Armed. My Baud Rate is set to 19200 and I'm using 8 Data Bits and 2 Stop Bits so not sure what I'm doing wrong.
If it helps, when I try to arm using the Home Assistant Texecom2MQTT add-on, it arms but I get this error in the logs and the Home Assistant side hangs on "Arming":
Unexpected start, expected 't', got 0x78
sometimes it says
Unexpected start, expected 't', got 0x29
Thanks in advance.
sometimes it says
Thanks in advance.
