The Cost Of A Replacement Unit
29 May 2004
We have a double glazed window which has condensation between the glass.
The glass is approximately 120cm x 90cm.
We have had quotes ranging from £90 to £115 to replace the glass into the existing frame. Can anyone tell me if this is the going rate?
Thanks.
depends where you are really
but as there is not that much diiference i should say it is
The fact that you have had quotes ranging from £90 to £115 must tell you that it is the going rate. What's up do you think there is a conspiracy between themselves to keep the price artificially high for you ? Perhaps you want a firm to do it for £50 and make a fiver out of it. You don't say in your post where the window is but it could be off a ladder, on a tall gable wall, down a cellar lightwell etc, etc .If the quotes were a mile apart I could understand your question but these firms do need to make a living at what they do .I apologise if it seems like I am having a go at you but if you are still unsure then ask for another couple of quotes.
