- Joined
- 29 Feb 2004
- Messages
- 31
- Reaction score
- 0
- Country
I've just been to look at an old hot water system and suggested replacing it with an unvented system. The customer said he has gone off unvented systems because of the trouble they have had with 10 UV systems connected with their holiday flat. Apparently, one of the expansion vessels corroded and failed causing considerable consequential damage. He (on behalf of the residents committee) has been in touch with the manufacturers about this and their concerns for the other 9 vessels. Several letters have been exchanged, but he hasn't got anywhere so to avoid further trouble the committee replaced all 10 expansion vessels at their own cost.
All 10 systems were installed when the property was converted to flats 10 years ago. I don't know what sort of guarantee you should expect to get against corrosion for an expansion vessel, but I would expect the vessel to last as long as the accompanying cylinder.
Apparently, these vessels are of steel construction with a corrosion resistant coating. The manufacturers letters make no mention of this, they are only concerned as to whether the initial charge pressure was set to equal the incoming mains water pressure. Incorrect initial charge pressure causing the vessel to fail. I say that this is a total red herring and has nothing what so ever to do with the vessel failing.
Do you agree or disagree?
10 years old or not the fact that the manufacturer refuses to discuss the real reason for the failure leads me to conclude that these vessels were not fit for purpose and yet again the manufacturers would rather blame the original installer than admit that they are the ones at fault.
