the hot water tap in my house has lost its pressure
30 Dec 2004
Hi everyone,
Since last night all of a sudden the hot water flow from my kitchen and bathroom taps has become very slow.
Does anyone know why this would happen all of a sudden?
What can I check, has something gone wrong?
Thanks, any help would be appreciated.
Syed
before it stopped running fast did anyone fill a bath & did it start to splutter after a while or even stop. if it happened without anything else it might be a blockage in the cold water storage cistern above the cylinder. iv been to the same fault & have found dead mice stuck in the feed outlet of the tank. once found a bat .
thanks for the responses. I am not very technical with these things, so here goes:
I do not have a combi boiler in my flat, i have to turn on the hot water switch in advance to get hot water. Upstairs I have a big water tank that is covered by a sponge material and above that I have the cold water tank.
Far as I know there was nothing unusual whoch happened before the loss of pressure.
Hope this helps
Syed
the tank with the spongy stuff is a hot water cylinder. above it is the cold water Feed & expansion tank. The pipe that comes out off the bottom of the tank takes water to the bottom of the cylinder. Have a look in the top tank to see if u can see a blockage where the bottom pipe comes out of the tank. u may need steps & a torch.
Thanks for the response bab. I had a quick look but was not able to see much . I will try again tommorow day time. The pipe is behind the tank and i cannot seem to see the face of the pipe.
One other thing I forgot to mention is that the bath sink has one of them noisy motors on so we could have enough pressure for a shower, does anyone know if this will have anything to do with it. The pressure is still the same for the shower and therefore I dont think the problem is there.
thanks
Syed
thanks
Syed
