The new Bath is Shorter!
27 Jan 2009
Bath
I have a new bath (an Aloha) which is 75mm shorter than the old one
and is 10mm higher at its lowest leg setting.
What is the neatest way to make up the length
What is the best way to trim the tiles 10-15mm
the height shouldnt be a problem, when youve levelled it up to the tiles silicone it all around
and the short problem, you could build a ledge in the gap.
Build a nice ledge at the end of the bath. We have a gap of about 15-20cm at the end of ours which was filled as a ledge level with the end of the bath. It's then tiled in the mosaic tiles that we used on the bath panel. The only thing is you have to be careful not to allow water to sit on it, so as long as your gap's not under the shower area, you should be fine.
Remember when you tile the ledge to put a very slight slope down towards the bath so any water can run off.
