- Joined
- 27 Jan 2008
- Messages
- 27,486
- Reaction score
- 3,323
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
With an old disabled mother automatic items can really be a boost. The heating is set to come on automatically and the TV set to turn off automatically the oven maintains the temperature set automatically the phone rejects calls with no caller ID automatically, but most of the technology needs user input.
Be it a remote for TV or a remote for web cam most of what is done to assist is not automatic. The curtains may draw without needing to grab the curtain but one manually presses the button or pulls a cord to get it to do the function required.
Even then there is a safety problem. Her chair lift has a wireless remote to drop the leg and to be frank it is rather dangerous as there is nothing to detect anything in it's path. And this is manually lowered by pressing a button on the remote.
I think the idea with cars to have doors auto lock when engine is off and ignition key removed does help. However it is also a pain when you have put the keys down inside the car. My house has an automatic door lock, when we leave and shut the door it requires a key to gain entry again. My father-in-law has a security door with many leavers which mean it is unlikely to be jimmied open but it does not auto lock you need to lift the handle up and manually turn the key.
Since windows are made of glass and an automatic centre punch can remove the glass in seconds what is the point of having a high security door? My automatic one is far better.
I like the idea of when driving home the global positioning on my phone tells it to automatically turn up the central heating ready for when I arrive, and setting the house alarm automatically turns the central heating down, but there has to be a manual over ride if I am visiting my father-in-law next door but one for Christmas dinner I want to be able to manually turn my heating down.
I have worked in large stores where heating was controlled centrally in London for a store in Chester it simply did not work. If outside is a really hot day then store needs to be cool maybe 18°C but outside temperature zero then in store maybe 22°C is more appropriate.
So yes use the Arduino to automatically control temperature using occupancy sensors, but it also needs to read the weather report to see what the temperature will rise to. If likely mid-day temperatures will sore to 26°C then want to keep house cool. Last thing we will want is getting house to 20°C in the morning. So I have a simple thermostat which although automatic I can manually turn down when forecast says it will be a warm day.
