    Dismiss Notice
central locking Toyota RAV
Discussion in 'General Cars' started by EAGLEBLOKE, 29 Nov 2005.
  1. EAGLEBLOKE
    EAGLEBLOKE
    14 Apr 2004
    50
    Thanks Received:
    Middlesex
    Country:
    Remote control for central locking suddenly stopped working, its a 2 button unit,lights up when you hold it down but no reaction. Have also tried spare also no reaction. put new batteries in both but still no luck.All doors still automatically open and lock by key in drivers door. HELP
  2. Sponsored Links
  3. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    Which year RAV4?
    I have some info if you want send me your email address (address in my profile).
  4. andy
    andy
    14 Sep 2004
    3,971
    Thanks Received:
    2
    Country:
    not enough replies in the 4 mins you waited since this thread?
    we are not paid to be here 24 hours a day and have a response to you within minutes. just wait like everyone else does, or take it to a dealer.
    and after a very quick look over the the car forums, i notice that you have posted this a number of times but didnt get a reply. ITS BECAUSE NO-ONE KNOWS. GET THE HINT.
    try a forum thats only for cars, youll probably get the info you need
  5. EAGLEBLOKE
    EAGLEBLOKE
    14 Apr 2004
    50
    Thanks Received:
    Middlesex
    Country:
    RAV4 is a 1997 R reg. Any info you can send would be appriciated.
  6. Sponsored Links
  7. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    The info I have is for a year 2000+ model, hence it may not work. Are the keyfobs manufactured by Toyota or are they an aftermarket add-on?
  8. EAGLEBLOKE
    EAGLEBLOKE
    14 Apr 2004
    50
    Thanks Received:
    Middlesex
    Country:
    Key fobs are manufactured by Toyota
  9. Quick Fit
    Quick Fit
    6 Jan 2005
    115
    Thanks Received:
    Country:
    Have you tried re-setting the system?. Put your key in the ing, start up the engine, then press your key forbe. Stop your engine, remove key. Get out of your car and try again outside. You might have to do this a couple of times. good luck.
  10. EAGLEBLOKE
    EAGLEBLOKE
    14 Apr 2004
    50
    Thanks Received:
    Middlesex
    Country:
    Have sorted it.
    If anybody else has same problem then this is the secret. :eek:
    separate each fob (make sure car is unlocked first)
    With the fob side with the battery on disconnected from the side with the buttons on, press the buttons one after the other lock - unlock - lock - unlock for about 10secs as fast as you can (this discharges the fob)
    Rebuild each key fob
    Stand at the drivers window and press and hold the lock button for 10 secs & then 1 single press of the unlock button and it should code :cool:
Loading...
Share This Page
