Hi all,
I'm about to buy a house which has some very old sections, with walls as old as 1590. These are probably the best part of 900mm thick, granite walls.
There's a little damp on a couple of the corners of the property with these external walls, so I'm looking to find a decent solution for this, though I've been reading mixed opinions. I should note that the outside walls are all feature walls, so external thermal cladding isn't an option, and we can only look at internal solutions.
Here are the options I've heard so far:
1) Thermal board over the current plaster. The adhesive for the boards is added in a continuous line running a few inches from the edge of the boards, sealing the moisture from the outside. This eats into the room space somewhat.
2) Similar to the above, but removing the current plaster first, perhaps using metal batons to mount the boards. Thicker thermal board can be used for this, as it would eat less into the room space.
3) Special permeable plaster and paint that allows the moisture to leave the walls to be dissipated within the room.
What is everyone's opinion on this? I'd like to improve the thermal properties of the walls, so the thermal board sounds good, but to me, sealing in the moisture into the walls seems like a great way of creating a very serious mould and wet rot issue that you don't notice until it's really serious and widespread.
Thanks in advance for any advice!
