Thermostat mixer leaking on left side
12 Jul 2024
Sweden
Hi everyone,
I'm dealing with a leaky shower mixer and could use some expert advice. The leak is coming from the left-hand knob, which controls the on/off function of the shower. I'm hoping to find a straightforward fix that doesn't involve replacing the entire unit.
I've attached some pictures of the shower mixer with the left-hand knob removed.
Could this be an issue with a worn-out washer or seal? If so, what steps should I take to replace it?
Any advice on troubleshooting or fixing this issue would be greatly appreciated.
Thank you in advance for your time and help!
You have a bar shower mixer. For some reason they are not as reliable or durable as round mixers.
However, yours is surface mounted and the connections are easily accessible.
A new replacement would be easy to fit and not expensive.
