I'm installing a bar shower, so far I have put in the hot and cold feeds using JG push fit and then put copper tails on. I have tested for leaks, and have wrapped the copper in insulation tape as I read they can get pitted if just plastered over. I was going to plaster over, tank and then fit shower panels.
Questions.
One: I have read that you should not plaster the feeds in the wall, ( internal wall) how could you fit a bar shower if you don't?
Two: do I need To put the pipes in foam sleeves due to expansion? If plastering over?
Three: cut off valves, where could these be installed if pipes are plastered in the wall, I cannot see where they are fitted on a bar shower fitment.
Questions.
