Hello all
Have just had a bathroom refurb done by a local firm and am having a problem with the thermostatic shower now I've come to use it for the first time.
During the refurb, the shower was over the bath and has now been changed for a standalone shower cubicle - re-using the shower in the original position (but re-plumbed).
(The Bath is now moved to the other side of the room)
The boiler is a combi (Vaillant Ecotec 937) and has been working fine with the thermostatic shower (Mira Excel) for ~12 months.
A pic of the shower...
The flow is controlled from the lever on the left and the temp on the round part.
With the flow on full as usual, no hot comes out until the temp setting is set on the lowest end (1).
It stays scalding until the temp setting gets to the top end (8/9) then it step changes to go freezing cold.
Is it possible that the pipes are now connected the wrong sides, or do thermostatic mixer showers not care ?
The bath and sink are producing hot and cold fine in their mixer taps.
My concern is that as the fitter re-used our shower (which did work fine before!) he has either broke it or it's failed somehow and will not help now the job's been paid.
The only other thing I've noted is that the pressure indicator on the boiler looks low. Not sure if this is irrelevant and this gauge only applies to central heating?
Help appreciated as I will call him tomorrow and would like to know some more background first.
TIA
TIA
