Hi all.
Used our new shower for the first time last night all appeared fine except that the temp range only goes from quite hot to hot - ie if I turn it all the way round to cold - it's still hot water (but less so) when you expect cold. I cant call the plumber back as this was done two plumbers ago (long story) so I'm looking into this myself in the first instance.
Been looking at the manual here at work and it sounds like the hot & cold might have been installed the wrong way around ?. This apparently can be cured by taking out the cartridge and turning it around 180 degrees.
Does this sound feasible ?
This is an unvented cylinder system.
Cheers.
Cheers.
