Hi there. We had a new heating system installed and had thermostatic valves in all rooms. They all seemed to work perfect and when you lowered the values the heat seemed to work with a good flow and kept the room warm or a long period of time. Recently I have noticed problems with them. If you turn the valves on they seems to just heat up and then cut-off and then do not turn back on. For example if you leave the valves at 4, it heats up and then cuts off and does not turn on again unless I turn it off and back on to 4. This never happened before and now I could leave it on for a an hour and it does not come back on. Even when the house is very cold…. And it’s a old house its always cold! They seem to say on longer and work better the less radiations you have on, and if there is only one it seems to stay on longer. I seem to recall this issue started when we had a bathroom refit and new radiator installed which is not on a thermostatic valve. Is that just a coincidence? Does anyone have any suggestions what the issue might be? Many thanks!!
