This is what I found under the loft insulation
Why are you not getting the hint from the repeated changing of your posts, by the mods, to remove those arrogantly unfriendly huge inline images?
PS - as you can't be @rsed to behave properly, I can't be @rsed to look at your photos.
I do not know how to make them smaller, that's why :!: :!:
Rupert suggests that instead of using the "IMG" button you use the "URL" button.
Mod Rupert
Edit:- Now I know how to make them smaller :!: (Thanks Mod Rupert)
...as you have not posted a question.....
Is it bad? Yes.
Have they used the wrong cable cores? Yes.
Does it need re-wiring? Yes
Do you need help? Yes so ask away
Is it bad? Yes.
I have changed the old joint, & put in a New JB & a New piece of cable.
It'a a very nice JB, well done
What have you done at the ceiling rose?
I connected the other end of the new piece of cable to the ceiling rose
Yes you do - my suggestion to use ImageShack would allow you to resize them.
Alternatively, if you want to resize them yourself, there are numerous free- and share-ware image manipulation tools available for download - the two I use are ACDsee and Graphic Workshop Professional.
That hasn't actually made the images any smaller though... :?
MDBalson, you are, if I may say so, a true artist at work. :wink:
Try not to get paint on your nice trainers though! :P
They are old trainers for doing DIY in
