- Joined
- 1 Nov 2006
- Messages
- 125
- Reaction score
- 0
- Country
I'd like to propose a double garage attaching to our house to the planning peeps, but not sure on how / method of /construction (which they'd like to see due to various factors).
Basically it needs to be as light as possible, have as small a foundation as possible, but also tie in with the house appearance. The house is a few courses of brick with rendered block above.
What would be the lightest / least intrusive footing method of construction to gain that appearance? Timber with some fake bricks on the lower section? (could be tricky - I've got bricks that are nigh on impossible to get a match for in proper brick!) or would lightweight block over real brick be almost as light? Can that go onto a lightweight slab footing of some description or would it be better to go for piled ground beam?
Key thing is the footings / base - keeping them as light and small as possible (if you haven't guessed it, it's due to protected trees nearby)
