I'd like to remove my fireplace. It seems fairly straight forward. But there's 2 fuse points.
So it goes fireplace hardwired into fuse box one (13A). This is on the left, has black fireplace cable in, grey cable out to right. As you'd expect. (at least I would).
But then there's a second fuse box on the right with a switch (13A). This has 3 sets, what appears to be 2 in, 1 out (to the other box).
My plan is, remove the fireplace, remove the left box and plaster over. Take out the cable between the two boxes. I'd like to remove that right hand box too, but it's not essential.
I'm assuming that the left box is an extension of the right box which is A: a spur from somewhere, B: on it's own cable. But I'm wondering really, why is there 2 sets of cables coming into that right hand box?
For your info, there is a double socket and aerial point 7ft to the left at the other end of the room. There are no sockets to the right. But a double on the opposite side of the wall in the corner (if you turn around). If I cut the power at the consumer unit to "sockets", it disconnects power to the fireplace switched fuse box.
Ultimately, I want to put in some LED downlights on this wall and take the power from the far left double sockets (it's next to a soil stack I can run them through). Do you think the chances are the fireplace spur comes from the left sockets to the right fuse box then doubles back on itself to the left fusebox?
