Thread sizes
18 Mar 2017
Wales
Is the thread size of nuts on 15mm compression fittings (specifically isolation valves) in the UK standardised, or does it vary with manufacturer?
Virtually all are 1/2 inch BSP thread. Prestex fittings historically used a different thread ,not sure about now.
Thanks guys. I was hoping to do a quick swap of an isolation valve, re-using the old valve's nuts and olives. I'm guessing the old (weeping) valve dates back 10 years or so. Doesn't look like a Prestex one.
You’d be unlucky if it’s not 1/2 inch. Use a bit of thread paste on the old olive if you don’t change it.
