- Joined
- 27 Jan 2008
- Messages
- 27,549
- Reaction score
- 3,330
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I was under the impression that with a Class II supply like for example with a shaver outlet that there should be no provision for an earth so that no one will try plugging in a Class I item.
My inverter is clearly marked Class II only but has a 13A three pin socket. I have missed this in the past just did not read all the printing on the unit only looked at the 150VA 230V and looked no further.
My son's old inverter before he sold boat had a large bolt clearly marked earth and bonded with some 35mm to boat hull and to be honest never even thought about the little one I use in the car.
I had expected to find the negative was cross bonded to earth but of course there are still some earth return or positive earth vehicles so that would have really been not at option but there is no earth bolt on the unit to correct to earth even if I wanted.
In real terms it's a IT system and with such low power only ever likely to supply one item in the same way as with the shaver socket which is also an IT system. So not really a problem.
But if it was to be used at work rather than at home what would be the situation if presented for "PAT" testing? Should it be removed from service as it has a three pin socket and no earth?
And since unlike rest of Europe we don't have two pin sockets what could be used instead of the 13A outlet?
Your thoughts please.
