Shortly after my central heating kicks in there's a loud thumping sound coming from the pipes. The sound moves around relatively quickly but generally comes from the run of pipes between the boiler and the pump. Occasionally it's accompanied by a gurgling sound, and the pump sounds as if there is air running through it.
I have an open vented system, the feed and expansion tank is well covered, seems to be clean, and is working. What is odd though is that the pipe feeding from the tank gets a lot hotter than the expansion pipe too the tank when the banging sound is happening. The pump seems to be going in the right direction!
The house has a mix of rads at different ages, some very old. I've replaced some, and flushed through others.
I've taken the floorboards up where the pipes run, they're not moving or banging into each other.
I've put cleaning agent in the system, which i will flush out on the weekend, but I'm at a bit of a loss what to try next? From previous articles I've read it sounds like there's air in the system, but how should I go about getting it out? I repeatedly bleed the radiators and pump to no avail.
Many thanks.
Many thanks.
