Tightening loose taps.
19 May 2007
I've got some Bristam mixer kitchen sink taps and they are loose. The threaded rod below the tap is loose and need tightening. I think the only way to access it is to use some sort of very long socket spanner but I can't seem to find any. How do people tighten the rod from below?
you are correct it does need a long box spanner they are available as a set of 2 from most plumbers merchants
Tap spanners exactly as you suspect from plumber merchants...
Ah, too slow :oops:
