I am about to insert a concrete lintel (65mm x 100mm x1800mm) into an external load bearing wall, and I was wondering if it would be easier to use tile adhesive instead of normal mortar to fix the lintel in place.
From what I've been able to read, tile adhesive is similar to normal mortar, except it has additives which make it stronger, especially when in thin layers?
Any advice/thoughts would be much appreciated,
thanks,
thanks,
