I have a small low powered (450w) tile cutter with a 180mm diamond cutting blade. works a treat for tiles and i was wondering if i can change the 180mm blade to a wood / mdf blade.
I would then use it to cut MDF based laminate flooring ( 8mm).
the tile cutter is from wickes in UK (is this a UK based forum !?)
can anyone foresee any problems in doing this?
according to a question on the support page .
http://answers.wickes.co.uk/answers/9987-en_gb/product/186878/questions.htm
can you buy replacement blades for the 450w tile saw?
Yes. Wickes sell such blades.
Alternatively you could get 25mm bore, 180mm diamond discs from another supplier and fit those.
