Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I want to lay rectangular tiles in a brick pattern. All the tile spacers I have seen seem to be the '+' shape which are no good unless i end up cutting one of the ends off. Do they come in a 'T' shape?
You would be better sticking them in sideways. When the grout has dried you can easily pull them out. Makes grouting afterwards a lot easier. I never use tile spacers the other way. Found it to be a hassle because if you want to grout really neat then there will be thin weak spots just above the spacers.
If this is flooring the answer is different but it is normally quite easy to break one end off. That's what i'd do.
