Can anyone advise as to when the plastic tile trim should be fitted around windows or doorways? Should it be placed around these areas with the adhesive first before you tile or are the trims pushed underneath the tiles and you are fitting them?
Some people fit them and let the adhesive go off first - I prefer to fit them only minutes before tiling around the window reveal, so that they can be tweaked and aligned with the tile edges.
