Hi, I have a flat in a purpose built block with a balcony off my living room. The floor of the balcony is currently covered with a tarmac and grit surface similar to the sort of covering you would find on a flat roof.
The problem is that at this time of year it is not possible to stop grit and dirty water being walked into my flat, I don't want to put a door mat over my carpet so I was wondering if it is possible to remove the existing covering and replace it with floor tiles or even paving blocks/stones?
Does anyone know if this is possible and if so suggestions as to the best tiles or paving to use?
Thanks Carole
Thanks Carole
