Hi all
We are laying 6mm Tilemaster cement boards over floorboards, and just wanted to know which is the best or most commonly used method of installing these?
- A layer of rapid flex tile adhesive, then screw the boards into the flooboards using 25mm screws
- Use 'green grip' adhesive on the backs of the boards, before laying and securing with screws
- Simply screw the boards to the floorboards without any adhesive
If using adhesive, should you use the manufacturers own products, or does it matter?
