Which adhesive for laying underfloor insulation boards?
24 Oct 2009
Can anyone confirm what adhesive is suitable for laying 6mm insulation boards onto an existing cement floor?
Warmup's website says to use a cement based flexible adhesive - is the same as the ready mix tubs of flexible tile adhesive and grout? Or is it the stuff you mix up yourself?
Any links of what I need would be useful cheers.
Wrigthy
"BAGGED FLEXY" addy as u have been told..
prime floor with bal sbr up the room then when dry accross the room.
6mm notched trowel apply flexy addy.
put ur i/boards down in a brickwork pattern.
then depending on size of tile 8-12mm notched or halfmoon trowel.
if porcelain tiles make sure u get siutable addy for them.
pop into a tile shop they will have all u need mate
DONT USE THE STUFF U GET FROM B&POO AND THE LIKES!!!
Cheers tictic,
I'm only laying the i/boards...a tiler is coming to do the tiles.
Thanks for your help.
Wrighty
