When cutting a tile to fit around an immovable object (in this case a pattress box for a fused outlet) is it possible to cut the tile into an l-shape? For example, take a 6 inch square tile and cut a 2 inch by 2 inch square out of one corner?
The only way I can think to do it is to run the tile cutter across the tile to make a 4 inch wide piece and a 2 inch wide piece, then run the cutter across the 2 inch piece to take the end off and glue the tiles in place together.
Now this doesn't sound like it would give a good finish! What tools and methods would I use to cut it leaving the tile in one piece?
