Hi there,
I am about to tile a kitchen floor with 10cm slate tiles. The units have recently been fitted.
Couple of questions.
1. The floor has vinyl (marley) tiles stuck down onto concrete. I have tried using a heat gun and a hammer & tough scraper but with no joy. They chip (as expected) and are hardly coming away. If a scarify them and use a flexible grout and maybe apply pva to the surface would that work ok?
2. Secondly do you grout along the sides of the recesses for the washing machine, d/washer/ fridge bearing in mind there are no kicker boards there? If the wood contracts at all will that not crack the grout? I suppose using a flexible adhesive & grout should sort that?
Many thanks in advance for your help!
