Tiling Question
9 Jan 2005
Hi
I have just bought my first house and am in the process of renovating it.
I am tiling both the kitchen and bathroom floors, they're both currently just floorboards. I have been recommended to put down some marine plyboard on top of the floorboards before i tile to stop the tiles cracking. However nowhere i've tried so far sells marine plyboard (which i assume is waterproof?) can i use normal plyboard and then waterproof it myself with some sort of paint on water proofer?
thanks for any help.
Hi Borris,
marine Plywood is a specialist material and over the top for your specification.
All you need is a construction/exterior grade, wbp plywood, which is available from any builder's merchant, better still, flooring supplier. It is available in 4mm and 6mm thickness and the 4mm is usually adequate in a new home...and easier to work with. Lay the plywood at right angles to the direction of the floorboards, if possible, and nail at 100mm centres with 1" annular/serrated ringnails (available from same suppliers).
You could even use hardboard, but in wet areas such as kitchen and wc the plywood is a safer bet.
Cheers.
Jim.
Thanks for your help.
The house i have bought is a 1930's construction does that make any difference to the thickness of board to use?
Hi Borris,
If the floor is sound and fairly level then the 4mm plywood is fine, and its easier to work with.
If there are a lot of gaps between the boards (i.e. the plumbers and central heating engineers have lifted them!), and if theres a lot of cupping and ridging in the boards, then 6mm plywood is better.
If the floor is really bad then a skim coat of latex screed first is a good idea before laying the ply.
Also try to make sure that the edges of you plywood sheeting don't land on the edge of a floorboard, if the floorboard moves then the edge of the ply will move with it.
