- Joined
- 12 Oct 2024
- Messages
- 211
- Reaction score
- 11
- Country
Hello,
We are tiling floor and walls using 300 x 600 (9mm thick) tiles. The floors are bare concrete and the walls are 12.5mm plasterboard with a paper covering.
I'd be grateful for advice:
A) do we need to use primer on the floors and walls? If so, which type? Gaps between plasterboard have been covered with scrim tape so far.
B) which tile adhesive would you recommend for the task, bearing in mind the previous question?
C) what is the minimum and maximum thickness of adhesive? Because of an uneven concrete base, we could ideally do with going as thin as 3mm and up to 15mm to ensure an even surface. Could go above 3mm if absolutely necessary.
Many thanks
John
Many thanks
John
