Timber frame cavity insulation
27 Aug 2014
Just reading though the kingspan literature for insulating a new timber frame building and it says you need to leave an air gap between the outer sheathing.
Why is this recommend? The osb sheathing will act like a vapor barrier so the back side don't breath will it?
Is there a way to fully fill the cavity, maybe breather membrane, fully filled PIR cavity then osb on the inside?
The cavity acts as a vent for the timber frame, and it keeps penetrating moisture away from the frame. Membrane also needs air on one side to perform.
So you insulate within the frame.
But a vent where? There will be no air flow in that void. The OSB is basically impermeable so is the pir; the tops and bottoms are timber so it's a closed box, there should be no air movement in there.
You might get a bit of moisture if the OSB is saturated but that's what the gap between the rain screen and breather membrane is for.
What am I missing?
But anyway my real question is can I full fill with foil faced board?
And yet not many ships are built out of OSB. Strange
The cavity is not a sealed vacumm. It's vented. Either with vents if there is a rainscreen, or via porosity if the cladding is permeable. That's what you are missing.
Think I have miss led you, not a cavity between rain screen and breather&OSB but in the frame between OSB and pir
Yes so why have they said you need one?
Never mind, I took a fresh copy off their website and it has that bit removed, I must have had an old copy?
