Time Lag Light Switch
9 Nov 2006
Bristol
Good evening. One of the light switches in my communal hallway has been broken for 2 months. Unfortunatly, my landlord will do nothing about it and it's got to the point that I want to replace the switch myself. It's dangerous having to walk up the first flight of stairs without any light. I understand about Part P and the implications of doing this work myself, but I'd rather take that risk than walk up the stairs in the dark again.
I have changed many sockets and switches before, and I have a voltage tester (not a neon screwdriver). I can isolate the supply at the landlords consumer unit; I've pulled the fuse and all the emergency lighting comes on in the hallway.
My problem is finding a replacement switch. It's made by RF part no: 279-8614, so I hoped to replace like for like. But, I can't buy from RF unless I have a business account with them. So, can anyone tell me if there is another switch (MK, GET etc) that will do the same job as the current one.
The current switch can be seen here
It's the middle one of the 3; the illuminated switch.
Thanks for any help you can give me,
Ben
_____________________________
Lynda, moderator
edited link to make post easier to read. (but RS website has timed out)
Hi ch427
Many thanks for your reply. I forgot to mention in my first post that there are 4 lights in this hallway and 4 switches. (entrance, ground floor, first floor and second floor). I'm not sure if the PIR switch is compatible as it seems to only replace a standard light switch. I've opened up the broken switch and there are terminals for "slave switches", plus the supply from the consumer unit.
Can you post a photo of the offending mains switch?
Can you see any brand name on it?
I can't work out how to edit a post on here... I just realised in my first post I said the switch was made by RF when I should have said RS :oops:
There is an 'edit' button on the top right hand corner of every post you have made.
Thank you, RF lighting! I couldn't see it because I didn't drag the scroll bar across enough :oops:
______________________________
lynda, moderator
now use the
button to see how I made the link smaller
I wouldn't be worrying about Part P, I'd be more worried about my liability should someone get injured or even killed as a result of anything I did.
Thanks to all who replied. I went to an electrical wholesalers today and asked them if they could recommend a switch. I went for another electronic switch, but made by Aurora(?) Everything is working nicely now :P
