Yes I have 9, that is 5 of these
but bluetooth version, and 4 of these
and although the former only cost me £15 each and the latter £36.50 each I find the former in general better, I believe the best is this
the Drayton as it have algorithms to work out when to switch off, but as to if worth £44 each not so sure. So I will start with the Energenie which was the first ones I bought.
It took some setting up, as the TRV was fitted on the return, and as a result radiator got hot, then the valve closed causing it to over shoot, so the lock shield valve needed careful setting, but the display
makes it easy, if current over target close the lock shield a little, and if current under target open it a little, and once set they were spot on. However the anti hysteresis software was a little OTT so set to 20°C form 16°C it reaches 18°C fast but last 2°C could take 2 hours, so I would cheat and set to 22°C for 1 hour then back to 20°C and then spot on. But there was very little manual control, you had to use phone, tablet, or PC and you needed the hub, another £48.
The eQ-3 much cheaper the bluetooth
does make setting easier, but unless two TRV's in the same room not really required, as everything can be manually set, I have seen manual version down to £10 each, it has window open detect which is not on the more expensive energenie model and I find I don't use the phone once set, the right button swaps from eco to comfort and back so I just press the button if I use room early.
The bluetooth version will only link to one phone, so wife controls 2 and I control 3.
However I find the house does not cool that fast, so although set to 16°C it never cools that much, and of course the boiler must be running for room to heat up, although the energenie using IFTTT will geofence, I use the Nest Gen 3 wall thermostat to do that, in theory I should be able to control with my Nest Mini, but the Nest Mini is like a mischievous little boy, and does its own think, so will not trust with heating.
