Hi All
I have the combo boiler mentioned in the subject line with the optional timer...I've just moved into this flat, and there is no instruction booklet. I've checked the docos online, however none of them mention how to use the timer.
The timer is a circular black device with the 24 hour clock written on it. By the times are white clips that can be pushed into the circle or out towards the edge of the circle (I assume this is to indicate whether the boiler should be on or off at the time).
Inside the cirle is also a switch that can be set to I, 0 or in the middle.
Hope this makes sense. Does anyone know how to actually use this thing? At the moment, the switch is set to I so I guess this means it's on all the time?
Cheers
Cheers
