…that is the question.
I've just refitted the family bathroom of our 19-year old Bovis house in the hard water area of Hertfordshire. The wife wanted a nice shiny chrome heated towel rail instead of the radiator. We got a cheap and cheerful Kudox one from B&Q which is now repositioned on the wall and I am all ready to get our regular plumber to come and extend the 10mm small bore pipes to reach it.
The instructions with the towel rail insist that: "the system MUST be thoroughly flushed with an industry approved CH cleanser. Following cleansing an industry approved CH protector MUST be added. Failure to cleanse and protect the system correctly is likely to cause small pinhole leaks and invalidate the guarantee…."
To save on time and charges I asked my plumber if I could cleanse the system myself before he does the work and asked him for a recommendation re the make of cleanser to use. He suggested Sentinel so I got X400 to cleanse and X100 as inhibitor.
The system is driven by a Baxi WM 38 3RS in the garage heating 10 radiators and hot water in a pressurised cylinder in the airing cupboard. The header tank is also set high in the airing cupboard. We have never flushed the CH system in 11 years and for certain the previous owners who had the house from new never did either.
I have had a peek into the header tank to see how to tie up the ball valve. There is a lot of "scum" on the water and a nice bright green trail of "slime" from the inlet valve down to the surface of the water. I lowered the ball valve to let some water in and the water in the tank started to "fizz" like undoing a bottle of fizzy drink.
Being naturally cautious I have stopped at that point. Can anyone tell me why the water in the header tank is fizzing when I add more water? Does this mean that the water is treated with an inhibitor already?
I am now dubious about flushing the system in case I cause more problems with an aging boiler, pump, radiators water cylinder etc. Nothing has ever broken (so far) so everything is original but we are aware of neighbours in similar houses having to replace leaking rads, hot water tanks, boilers etc.
I have flushed out the old radiator from the bathroom to see if there was a lot of black sludge and there was none. There was a little black water when I first removed it but not a lot.
Should I leave well enough alone or flush? Or leave it to the plumber to do after he has plumbed in the towel rail? On that basis, if it does all go pear-shaped at least I have the professional on site to fix things?
Any advice gratefully received.
Graham
Graham
