Last couple of days i have been hearing some noises in the toilet cistern.
I have removed the lid and the water level is about 2 inches from the line at which it is noramly at.
The noise is coming from the top of the inlet valve.
If i touch it ever so slightly it then allows the water to continue into the cistern and then stops at the correct level on the side of the cistern wall.
Sometimes the noise is not there and upon checking the level is correct.
I am looking to replace this fill valve and i am looking at the screw fix item 47792
I assume these are pretty much a universal item ?
In that i mean as its not connected to anything other than the inlet water pipe there should be no reason why the item mentioned cant be fitted ?
My toilet cistern is mains fed.
Please advise,many thanks.
http://www.screwfix.com/p/fluidmaster-brass-shank-bottom-entry-fill-valve/47792
