- Joined
- 21 Sep 2011
- Messages
- 4,840
- Reaction score
- 1,170
- Country
In most cases you can reuse the old nut and olive.
To use the new one you have to pull off the old olive and nut, several ways to do it.
Use an olive removal tool.
https://www.youtube.com/watch?v=6kK9W3M3vT0
Grip it with pipe grips twist and pull.
https://www.youtube.com/watch?v=iCp0eZEh02k
Carefully cut the olive at 45deg with a hacksaw almost to the pipe and fit a screwdriver in the saw cut and twist to split the olive.
Call a plumber!
The new nut is pushed on followed by the olive the joint assembled and tightened to crimp the olive onto grip the pipe.
https://www.youtube.com/watch?v=NpIh1u_Y3h0
Lots more on youtube if you want to have a look.
If the olive has bitten so hard on the tube it has distorted the tube and created a waist don't change it unless it is impossible to use the old nut as removal will be very difficult.
Call a plumber!
