Bear with me for not knowing the technical terms, but if I did I probably wouldn't need to ask this question...
Our toilet is getting hard to flush. It's a bog-standard (ha) toilet with a cistern mounted just behind. When you press the lever, there's not the normal 'resistance' you expect on the lever, the same as if you tried to flush it too soon after a previous flush and it hadn't had time to refil yet. But the cistern is full. Sometimes it's worse than others, but it's getting worse overall.
Any ideas?
Any ideas?
