My mums toilet is constantly filling from the toilet valve. When I've looked at it, it doesn't matter where you put the float it keeps filling up.. quite slowly.
I couldn't work out how to fix it so she got a plumber out who managed to take the top off the valve and replaced the washer but problem came back.
I could just change the unit but the installer who fitted the toilet siliconed it to the wall and the floor...there's no screw fittings for it... and I cant budge it.
I bought one of these Flomasta Bottom-Entry Brass Shank Fill Valve from screwfix which is almost identical and thought I could unscrew the top and swap them over but the new one was sealed shut (does look like it should unscrew but doesn't). I ended up breaking it and just using the washer (most expensive washer ever) and putting the old one back together but it still runs.
I think maybe the old unit shouldn't come apart and is broken.... any tips on how to remove the toilet from the wall without breaking the tiles or do you think the unit can be saved?
